Inventor Forum
Create Sub-assembly from general assembly.
2 REPLIES 2
JJarbeau
1018 Views, 2 Replies
Hello
I created a general assembly (GA) and placed several parts and assemblies. After I realized there are too many parts and assemblies in the GA to reasonably place on a drawing. Now I want to remove some parts and create sub-assemblies. Is there an easy proceedure to select some parts in the GA and insert them into a new sub-assembly and (hopefully) keep the constraints intact?
Best Regards
Jeff
2 REPLIES 2
JavaLodge
in reply to: JJarbeau
You can select parts in your assembly and press tab to create a new sub-assembly from the selected parts.  Alternatively you can right click->components->demote and it will do the same thing.  It should be able to keep all of your constraints as well.
____________________________________________________________
Slow is good and good is fast.
JJarbeau
in reply to: JavaLodge
Just tried the "Tab" solution and is exactly what I was looking for.
Thanks again
