Hello
I created a general assembly (GA) and placed several parts and assemblies. After I realized there are too many parts and assemblies in the GA to reasonably place on a drawing. Now I want to remove some parts and create sub-assemblies. Is there an easy proceedure to select some parts in the GA and insert them into a new sub-assembly and (hopefully) keep the constraints intact?
Best Regards
Jeff
Solved by JavaLodge. Go to Solution.
You can select parts in your assembly and press tab to create a new sub-assembly from the selected parts. Alternatively you can right click->components->demote and it will do the same thing. It should be able to keep all of your constraints as well.
