Inventor General
JJarbeau
Message 1 of 3 (298 Views)
Create Sub-assembly from general assembly.
298 Views, 2 Replies
01-03-2014 10:02 AM
Hello
I created a general assembly (GA) and placed several parts and assemblies. After I realized there are too many parts and assemblies in the GA to reasonably place on a drawing. Now I want to remove some parts and create sub-assemblies. Is there an easy proceedure to select some parts in the GA and insert them into a new sub-assembly and (hopefully) keep the constraints intact?
Best Regards
Jeff
Valued Contributor
JavaLodge
Message 2 of 3 (292 Views)
Re: Create Sub-assembly from general assembly.
01-03-2014 10:16 AM in reply to: JJarbeau
You can select parts in your assembly and press tab to create a new sub-assembly from the selected parts.  Alternatively you can right click->components->demote and it will do the same thing.  It should be able to keep all of your constraints as well.
____________________________________________________________
Eat when you're hungry, sleep when you're tired. -Bruce Lee
JJarbeau
Message 3 of 3 (282 Views)
01-03-2014 11:01 AM in reply to: JavaLodge
Just tried the "Tab" solution and is exactly what I was looking for.
Thanks again
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
