Inventor Forum
Create Punch tool in inventor 2013
12 REPLIES 12
Message 1 of 13
3680 Views, 12 Replies
Dear All
I am beginner in inventor, and I have to create punch and put them in library so it can be used later. I can not do. someone to help me
thank you in advance for your answer
ps: Sorry for my bad English I'm a French and I don't speak English very well.
12 REPLIES 12
Message 2 of 13
mcgyvr
http://www.lmgtfy.com/?q=autodesk+inventor+punch+tutorial
There are numerous tutorials.. Have you tried those?
What problems are you having?
Can you post the files you are trying to create a punch from?
Message 3 of 13
in reply to: mcgyvr
I need to create a punch with an extrusion, which automatically pierces the room in which will gather have a place or have placed.
at school I do not use Inventor but I am in training, and the company welcomes me working in Autodesk
Message 4 of 13
JDMather
I think the first thing I would do is go through all of the built-in Help>Learning Tools>Tutorials and Skillbuilders.
Message 5 of 13
in reply to: JDMather
I Don't see this.
Message 6 of 13
JDMather
Click on this down arrow next to the ?
Message 7 of 13
yes but if I make a request on this forum is to have another tutorial.
I already find the inventor tutorial but I am looking for another tutorial to have a more precise idea of what I should do
Message 8 of 13
JDMather
Can you attach the file of what you have attempted?
There might be more tutorials here
www.mcadforus.com
http://au.autodesk.com
Message 9 of 13
the file is attached,
This morning I found a pretty good tutorial on http://au.autodesk.com   (http://au.autodesk.com/?nd=tech_talk_detail&article_id=10&jid=9835)
I'll look on the site you advice me.
Message 10 of 13
JDMather
First thing - I would turn off AutoProject Part Edges on Sketch Create, see
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Second thing, before anything else - place a center point in the first sketch for your Punch feature.
You have not created a feature with your sketch - so it is unclear what you want your punch tool to look like.
Can you attach picture of similar feature or complete the feature with whatever techniques you know and then someone will demonstrate how to do it as a Punch tool.
Search here as well
http://au.autodesk.com/?nd=classes
Message 11 of 13
I don't understand what you want,
sorry i'm french and y have not very good english
Message 12 of 13
in reply to: mcgyvr
Hi, I cannot seem to find the way to save this loft into a punch tool, can you help me do this or show me how, I would really apreciate it!!
Message 13 of 13
johnsonshiue
Hi! Punchtool (iFeature) is limited to some sketch-based features not all. Sweep based on 3D sketch path and Loft are among the ones being excluded unfortunately.
For a regular part, you could use a workflow to bypass the restriction. Basically, you make a source feature part. Then derive it as a separate body in the part you want to place the feature. Then use Move Bodies (Direct Edit) command to relocate the feature body to the desirable place. Next, use Combine feature to join or cut it.
Thanks!
Software Test Engineer
