Inventor Forum
Create Flat Pattern Command Missing
6 REPLIES 6
MelJM
3087 Views, 6 Replies
I recently switched to Inventor 2012 from a previous version. I cannot find the create flat pattern command. Some of my coworkers were able to customize their RMB menu to have this command, but I am not even able to do that! (They don't have the command on the ribbon, either.)
I attached a picture of my sheet metal ribbon... don't know if it's helpful or not.
6 REPLIES 6
JDMather
in reply to: MelJM
Attach that ipt file here.
Curtis_Waguespack
in reply to: MelJM
Hi MelJM,
This might help:
http://forums.autodesk.com/t5/Autodesk-Inventor/Sheet-Metal-Part-Has-No-Flat-Pattern-Button/m-p/3268...
If so, kudos to jeanchile for sharing the solution.
I hope this helps.
Curtis
MelJM
in reply to: JDMather
All I did on that part was create a face and add a flange, to see if on such a simple part the flat panel command would "appear".
Just started up Inventor for the day, and the command was there. I have no idea what changed between yesterday and today. Stay tuned, perhaps it will dissappear again?
sk
in reply to: MelJM
So, same thing happend to me today; the Flat Patten panel was simply just gone.
So i forund this post. No answer though..
Seems like your problem solved it self without knowing why.
Mine didnt. Tried restarting both inventor and windows, but still no Flat Pattern panel!
Then I tried opening the same files from my colleagues pc, and voila, no problems. Flat Pattern panel was on colleagues pc, but not mine.
So, to go to the action: turns out I somehow "turned the panel off". And heres how to turn on/off all panels after wish:
  1. Right-click a random place on the ribbon(only remember to do it in the tab of issue, in this case "Sheet Metal" tab)
  2. Choose "Show Panels" in menu
  3. give or remove check mark of the panel you want to add or remove.
- see attachment
Voilá!
/sean
methoni
in reply to: sk
Well done
Had the same problem,followed your  instructions and hey presto problem solved
Regards
jspalholz
in reply to: methoni
THANK YOU!!
