Inventor General
*Expert Elite*
karthur1
Message 1 of 2 (100 Views)
Accepted Solution
Create Block description
100 Views, 1 Replies
05-10-2012 07:52 AM
When I create a sketch block, there is a description area.  After the block is saved, how can I see this information again?  If I right click on the block in the browser, I cant find it anywhere.
*Expert Elite*
Curtis_Waguespack
Message 2 of 2 (92 Views)
Re: Create Block description
05-10-2012 08:21 AM in reply to: karthur1
Hi karthur1,
Edit the sketch block and then right-click anywhere that is not on the sketch entities, and then choose Block Properties.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
