Inventor General
Valued Contributor
Message 1 of 7 (318 Views)
Copy or exporting a material that is not in Style Library.
318 Views, 6 Replies
02-12-2013 01:19 AM
I can’t figure out how to copy a material (outside style library) from one part to another. Or how to do it with exporting and importing the material through a styxml file.
Valued Mentor
mpatchus
Message 2 of 7 (304 Views)
Re: Copy or exporting a material that is not in Style Library.
02-12-2013 03:51 AM in reply to: petter.moldestad
You will have to have READ-WRITE for styles enabled in your project file to do this.
In the part that has the material style you want to copy, SAVE the style to the style library.
Open the part that you want to apply that material to, and UPDATE the styles.
This should bring in the material style you saved previously.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
Valued Contributor
Message 3 of 7 (299 Views)
02-12-2013 04:02 AM in reply to: mpatchus
Thanks for your replay.
I had hoped it was a solution without saving to Style Library as it was in previous releases before Inventor 2013.
*Pro
sbixler
Message 4 of 7 (295 Views)
02-12-2013 04:20 AM in reply to: petter.moldestad
It entirely depends what version of Inventor you are using (always include this information in your first post!).  2012 and before is one answer, 2013 is a completely different answer.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Valued Contributor
Message 5 of 7 (291 Views)
02-12-2013 04:24 AM in reply to: sbixler
Yes, sorry that I forgot. I use Inventor 2013.
*Pro
sbixler
Message 6 of 7 (289 Views)
02-12-2013 04:29 AM in reply to: petter.moldestad
OK, simplest way I know of is to open the material browser and copy the material to the Favorites "library", then copy from Favorites to your new file.  The Favorites is technically a library, but it's not meant to be shared with other users, and as far as I know, you can't configure it to be anywhere else than in your Windows user profile.
The styxml method worked for Colors and Materials in 2012 and earlier versions, but not in 2013 with the change to Appearance and Material libraries separate from the Styles library.
Sam B
Valued Contributor
Message 7 of 7 (288 Views)
02-12-2013 04:35 AM in reply to: sbixler
So easy! :smileyhappy: Thanks a lot.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
