Is there a way to copy a drawing sheet and all it's views and annotations to a new sheet within the same drawing file?
Don't know about copying the sheet and pasting to the same drawing, but:
-you can create a new sheet
-copy existing views from other sheet
-paste to new sheet
Some more mouse clicks, but results are the same. Dims and anything associated with the view will be copied. This works for 2010...
You could also use attached VBA macro to copy the active sheet to a new sheet in the same drawing. Should work in any release of Inventor.
Sub copy_sheet() Dim oDrawingDocument1 As DrawingDocument Dim oDrawingDocument2 As DrawingDocument Dim oSheet As Sheet Set oDrawingDocument1 = ThisApplication.ActiveDocument Set oDrawingDocument2 = ThisApplication.Documents.Add(kDrawingDocumentObject, , False) Set oSheet = oDrawingDocument1.ActiveSheet oSheet.CopyTo oDrawingDocument2 Set oSheet = oDrawingDocument2.Sheets.Item(oDrawingDocument2.Sheets.Count) oSheet.CopyTo oDrawingDocument1 oDrawingDocument2.Close True End Sub
Cheers
Bob
Thanks for this Bob. This will come in handy...
EDITED: Bob, please see screen shots. Is there any reason why this macro would move my Section View away from it's original position??
