Inventor Forum
Copy Sheet from One Drawing to Another?
6 REPLIES 6
Bill.Schmid
3305 Views, 6 Replies
I swear I've done this before and now I can't make it work.
You can't copy a sheet within a drawing to duplicate it.  So, as a workaround, I saved a copy of the drawing to a different name and tried to copy a sheet back.  Pick the view in the browser, right click, copy.  Switch to the original drawing, right click paste in the browser.  All I keep getting is an error "Invalid input for Request."  I even think I remember getting this error before and finding a way around it.
So what am I doing wrong?
6 REPLIES 6
in reply to: Bill.Schmid
Im using Inv2012 from Plant design suite
I just tested...works ok for me...however view in newly created sheet neaded an update.
Bill.Schmid
I tried it yet again by saving the existing drawing to "temp", deleting all the views, copying the sheet and pasting it into the original drawing.  I think there was at least a quit and restart of Inventor in there somewhere, too.  This time it worked.
Your drawing has to be saved...
roland.andrag
I had the same issue, i.e. error "Invalid input for request" when pasting a sheet from one idw to another.
In the end I got it working by deleting the title block and border before copying (and then re-adding them afterwards).
Hi Roland,
Could you share an example exhibiting the behavior? The error sounds like a corruption to me.
Many thanks!
Software Test Engineer
MkEHWD
Ok I know its an old topic... so I just had this error and I think I find out what was the problem... TITTLE BLOCK! I had 2 tittle block named the same way but with slight modifications in it. I dont know of its because of the modifications or they both had the same name but I removed the tittle block on the sheet I wanted to copy, I copied the sheet and then I reinsert my tittle block. Works like a charm!
