I create piping systems with valves that each have a unique tag number. In some cases the systems are dupes and only the tag number changes. So my goal is to duplicate system A to a new system B directory and change the drawing and model names from A to B, then change the valve tags using design assistant. Should be easy enough, but no.
When I change the drawing and model names in the new directory to B and open up drawing B, inventor is still looking for model A is directory A.
I have tried a pack-n-go. I have tried save copy as. I have tried copying all filed using windows expolrer. I have deleted the .prj file and created a new one from scratch. None of these methods work.
Not only that, but when I try to edit one of my drawing views in the Drawing View DB, The file name of the view is grayed out and cannot be edited. Nor can I add any more views.
Any ideas?
Mike
Solved by blair. Go to Solution.
Probably use Design Assistant to make copies the following video may be clearer:
http://www.youtube.com/watch?v=jXu5spVKtGE
