Inventor General
Distinguished Contributor
Orest_iy
Message 1 of 3 (96 Views)
Copied by Design Assistant assembly cannot be altered in Design Assistant
96 Views, 2 Replies
04-10-2012 01:40 AM
Hello
I  just made a copy of assembly in Design Assistant.
I opened the copied assembly in Design Assistant to make some changes.
Parts are accessible but I have only "Clear" option possibe.
Please advice the possible reasons why?
http://screencast.com/t/VYsx600WSzQ
Orest Yavtushenko
Valued Contributor
Daniel248
Message 2 of 3 (80 Views)
Re: Copied by Design Assistant assembly cannot be altered in Design Assistant
04-10-2012 12:34 PM in reply to: Orest_iy
It is likely that your  _ASSEMBLY folder is a Library.
Check your Project settings, and if you have to make changes to a Library, use a suitable project (the one specially set up to enable changes to Library parts, with CAUTION).
Orest_iy
Message 3 of 3 (63 Views)
04-11-2012 10:56 PM in reply to: Daniel248
The assembly file does not belong to custom library.
If it even does I could not copy it from the beginning. As you can see I do copy of assembly and than open this copy which has accessible but not editable parts. The Standard Parts (library parts) are not accessible at all (grey).
Orest
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
