Inventor General
Active Contributor
brendeho
Message 1 of 25 (392 Views)
Convince me to stick with Inventor
392 Views, 24 Replies
03-23-2012 10:37 AM
I have a new job and the lead engineer doesn't like Inventor. I used to think she was just nit-picky, but after using the software and pushing it's limits - I've come across a number of trivial limitations.
What software will do the job and not break the bank? I'm not holding out with Autodesk product loyalty any longer.
Distinguished Contributor
Message 2 of 25 (379 Views)
Re: Convince me to stick with Inventor
03-23-2012 10:57 AM in reply to: brendeho
Inventor is good for certain applications, not too good for other.
Answering your question with the info you provided requires sorcerer's crystal ball.
*Expert Elite*
cbenner
Message 3 of 25 (376 Views)
03-23-2012 10:59 AM in reply to: brendeho
Well, you're not going to get much of a response, IMHO, unless you detail what some of your trivial limitations are.  What exactly is it that Inventor will NOT do?  If you give some info on what the problems are, people in here can either help you solve them with Inventor, or perhaps suggest a CAD package more suited to your needs.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
*Expert Elite*
Message 4 of 25 (374 Views)
03-23-2012 11:00 AM in reply to: brendeho
<snip>
Edited for professional discussion.
Obviously you have not provided enough information.
Maybe you should just ask the boss?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Active Contributor
brendeho
Message 5 of 25 (368 Views)
03-23-2012 11:02 AM in reply to: cbenner
Here's one of the issues: http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-won-t-sweep-or-build-pipe-run/td-p/3382491
Currently I'm creating a new pipe in the content center editor to use in the frame generator. Will reply if this works or not. I'm willing to admit that maybe this is my issue, and not Inventor.
*Expert Elite*
Message 6 of 25 (360 Views)
03-23-2012 11:06 AM in reply to: brendeho
Looks pretty trivial to solve to me.
You didn't supply your input information - so I ignored the thread rather than take my time to rebuilt it correctly for you.
Kind of like a student handing me a (wrong) answer to a math problem and asking me what they did wrong without showing me the work they did to get the answer.
I'm sure any of the other MCAD programs will solve your problem.
Active Contributor
brendeho
Message 7 of 25 (358 Views)
03-23-2012 11:09 AM in reply to: JDMather
I'd agree - looks very trivial. What input information do you need?
I have a 3d Sketch, and need to sweep a .250" OD .180" ID profile through it - as specified in the other post.
*Expert Elite*
Message 8 of 25 (350 Views)
03-23-2012 11:12 AM in reply to: brendeho
Obviously I already saw what you posted before.
Active Contributor
brendeho
Message 9 of 25 (346 Views)
03-23-2012 11:13 AM in reply to: JDMather
When you say input information, do you mean the part file from which the 3D sketch is based on? I'll post that in the other thread.
Valued Mentor
Message 10 of 25 (337 Views)
03-23-2012 11:21 AM in reply to: brendeho
Seeing as though you use piping and frame generator your choices are quite limited.  In this price range it's Inventor, solidworks or solidedge.  I have friends that are raving about spaceclaim, so I just started a trial, but it doesnt have piping.  I like the idea of getting rid of unwanted history and rebuild delays.
I switched from Sw to inventor and after 2 years its been a bit of a disappointment, but I wouldnt go back to SW even though it has a lot of good features.  If I had my time again I would try solidedge, but I also know people who switched from solid edge to inventor.  Perhaps the reason why so many people prefer the rhino with autocad solution is because they are all as bad as each other.  I have a big job due to start next week and I will be going back to autocad for the majority of this one.
2013 is out next week, maybe wait and see what it has to offer.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
