Inventor General
Member
collinseric
Message 1 of 8 (2,747 Views)
Converting a surface into a solid body
2747 Views, 7 Replies
09-28-2012 03:14 PM
I am trying to convert this composite surface into a single solid body, however when I try to stich the surfaces in the construction environment it always crashes. I have also tried edditing the STEP file import options but it still always opens as a composite surface.
Eric
JDMather
Message 2 of 8 (2,745 Views)
Re: Converting a surface into a solid body
09-28-2012 03:17 PM in reply to: collinseric
No file attached?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
collinseric
Message 3 of 8 (2,740 Views)
09-28-2012 03:20 PM in reply to: JDMather
I'm having touble uploading it... says the file size is too large... already compressd it in a zip. Solutions?
JDMather
Message 4 of 8 (2,734 Views)
09-28-2012 03:24 PM in reply to: collinseric
Depends on where you have it.
In Inventor?
Drag the Red End of Part marker above the Composite body and nothing in Construction (or Repair) environment.
Save the file in a rolled up state and then zip.
If still larger than 1.5 meg the limit is 10Meg over here http://www.augi.com
Member
collinseric
Message 5 of 8 (2,722 Views)
09-28-2012 03:48 PM in reply to: JDMather
JDMather
Message 6 of 8 (2,717 Views)
09-28-2012 03:58 PM in reply to: collinseric
The most obvious question - Why would you even need that as solids?  Wouldn't you simply purchase from the company?
Valued Mentor
Valued Mentor
wh
Message 7 of 8 (2,691 Views)
Betreff: Converting a surface into a solid body
09-29-2012 02:40 AM in reply to: collinseric
This seems to be a derived part from a SWX 2010 assembly, as can be seen in the translation report.
I've seen several similar parts, and most of them had lots of missing or distorted faces. SWX derived parts seem to be only minor quality.
With lots of spare time and some knowledge, you can rebuild these imports. But that's no fun.
Walter
JDMather
Message 8 of 8 (2,685 Views)
09-29-2012 04:03 AM in reply to: JDMather
If you need to include in assembly drawing - simply tell Inventor to include surfaces.
If you want it to "appear" solid - right click and turn off Translucent.
If you reall want to take the time to convert to solids you will need to create Groups in Repair (Construction) environment and isolate the different parts into different groups.  Patch the missing surfaces, stitch and promote. (an all day job on this assembly)
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
