Inventor General
Valued Mentor
BLHDrafting
Message 1 of 27 (4,145 Views)
Accepted Solution
Converting STL file to solid?
4145 Views, 26 Replies
04-07-2013 08:06 PM
A customer has supplied me an STL file. It opens in Inventor but I can't measure it or place it into an IDW to dimension it. Anybody know how to fix fix this?
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
*Expert Elite*
blair
Message 2 of 27 (4,138 Views)
Re: Converting STL file to solid?
04-07-2013 08:33 PM in reply to: BLHDrafting
It appears to only be a mesh item. Can you post the part.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Valued Mentor
BLHDrafting
Message 3 of 27 (4,133 Views)
04-07-2013 08:48 PM in reply to: blair
Thanks Blair. Here is the STL file. I had to zip it as the Forum complains about incorrect file extensions. Really?
Brendan Henderson
Web www.blh.com.au
Active Contributor
jameslovell4987
Message 4 of 27 (4,111 Views)
04-08-2013 05:08 AM in reply to: BLHDrafting
Thought to try the mesh enabler from labs? not tried it myself but it sounds like it may work for you :smileyhappy:
'In addition to Catia files, Inventor 2013 can import mesh data from STL files and from JT files. The Mesh Enabler for 2013 adds the ability to post process the imported mesh data to convert the mesh features to Inventor Base features.'
http://labs.autodesk.com/utilities/inventor_mesh
James Lovell
Windows 7 Professional (64-Bit)
Dell T5600 - Xeon E3-2687W 8(16) Core CPU
16GB ECC RAM, 2GB Quadro 4000, 256GB SSD
Autodesk Product Design Suite Ultimate 2015
Distinguished Mentor
rdyson
Message 5 of 27 (4,097 Views)
04-08-2013 06:47 AM in reply to: BLHDrafting
Here you go, assuming the STL was in mm's.
Fairly simple to remodel in Rhino using the mesh.
*Expert Elite*
blair
Message 6 of 27 (4,088 Views)
04-08-2013 08:38 AM in reply to: BLHDrafting
You beat me to it, I guess that's what happens when one is on the west coast.
Win7-64
Employee
wilkhui
Message 7 of 27 (4,086 Views)
04-08-2013 08:41 AM in reply to: BLHDrafting
Hi Brendan,
Did the mesh enabler plugin that James mentioned work for you?
Best,
Indy
Inderjeet Wilkhu
SQA Engineer
Autodesk ShapeManager
Design, Lifecycle and Simulation
Autodesk, Inc.
Valued Mentor
BLHDrafting
Message 8 of 27 (4,071 Views)
04-08-2013 02:53 PM in reply to: jameslovell4987
Thanks James. That add-in worked although the output is ugly (lots of mesh faces). But at least I can measure it.
Brendan Henderson
Web www.blh.com.au
Valued Mentor
BLHDrafting
Message 9 of 27 (4,070 Views)
04-08-2013 02:55 PM in reply to: rdyson
Many thanks rdyson. Rhino did a better job than the Inventor mesh add-in, which also worked but created a lot of faces.
Brendan Henderson
Web www.blh.com.au
Valued Mentor
BLHDrafting
Message 10 of 27 (4,069 Views)
04-08-2013 02:57 PM in reply to: wilkhui
Yes Indy, it worked, although the output created a lot of faces. But as these don't appear on an IDW it's okay. Thanks.
Brendan Henderson
Web www.blh.com.au
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
