Inventor General
Employee
wilkhui
Message 11 of 27 (789 Views)
Re: Converting STL file to solid?
04-09-2013 09:12 AM in reply to: BLHDrafting
Hi Brendan,
Thanks for the update - the intention of the Labs plugin is to be a technology preview so if you have any feature requests or specific feedback then I'm sure the Mesh Enabler team would be happy to hear about them!
The links on the right of their page provide ways to get in touch:
http://labs.autodesk.com/utilities/inventor_mesh
Best wishes,
Indy
Inderjeet Wilkhu
SQA Engineer
Autodesk ShapeManager
Design, Lifecycle and Simulation
Autodesk, Inc.
*Expert Elite*
JDMather
Message 12 of 27 (785 Views)
04-09-2013 09:32 AM in reply to: BLHDrafting
BLHDrafting wrote:
Yes Indy, it worked, although the output created a lot of faces.
I didn't try on your model, but you might be able to use Delete Face with Heal option to simplify faces (especially the planar faces.  Looks like Rhino does a much better job.
It would also be nice if Inventor recognized cylindrical faces - it doesn't look like Rhino did (try measure radius).
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Mentor
BLHDrafting
Message 13 of 27 (773 Views)
04-09-2013 03:06 PM in reply to: JDMather
JD, Delete Face with Heal cleaned up the large flat faces but touching any of the curves/fillets resulted in very odd and unusable results. Thanks for your input.
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
Employee
wilkhui
Message 14 of 27 (765 Views)
04-10-2013 01:11 AM in reply to: BLHDrafting
Hi Brendan,
Could you clarify what you mean by odd/unusable results?
The nature of a mesh means that this model is made of planar faces, so if you zoom in far enough you'll find that everything is actually a straight edge.
Hope this helps,
Indy
Inderjeet Wilkhu
SQA Engineer
Autodesk, Inc.
Valued Mentor
BLHDrafting
Message 15 of 27 (746 Views)
04-10-2013 02:07 PM in reply to: wilkhui
Indy, if I do the Delete Face with Heal on the outward rounded corners they turn into triangules or square (see picture). Similar with trying to turn the internal holes in rounds.
Brendan Henderson
Web www.blh.com.au
Employee
wilkhui
Message 16 of 27 (728 Views)
04-11-2013 12:36 AM in reply to: BLHDrafting
Hi Brendan,
Sorry that this doesn't meet your expectations but I'd like to clarify what I meant above by 'everything is actually a straight edge'.
If you take a look at the snapshot below, I've zoomed in to an area of the model that looks like it may be round but this isn't the case upon inspection - you'll notice that it is a series of planar faces and this is typical of this type of file. I don't think that Delete Face can be expected to give the 'round' result you'd like to see.
The only method that I am aware of to make features from this kind of file is to remodel, but if anyone else knows of a way to 'convert' these shapes then please share.
I hope this makes sense but please feel free to follow up and I'll do my best to help.
Indy
Inderjeet Wilkhu
SQA Engineer
Autodesk, Inc.
Valued Mentor
BLHDrafting
Message 17 of 27 (708 Views)
04-11-2013 02:30 PM in reply to: wilkhui
Thanks for the explanation Indy.
Brendan Henderson
Web www.blh.com.au
nenaddj69
Message 18 of 27 (549 Views)
11-26-2013 07:32 AM in reply to: wilkhui
Can you explain how to use Mesh Enabler plug-inn, please? Thx.
Employee
wilkhui
Message 19 of 27 (540 Views)
11-26-2013 08:05 AM in reply to: nenaddj69
Hi nenaddj,
Paul Munford has written a detailed guide here.
You may also find the Mesh Enabler forum useful.
Hope this helps!
Indy
Inderjeet Wilkhu
SQA Engineer
Autodesk, Inc.
nenaddj69
Message 20 of 27 (536 Views)
11-26-2013 08:20 AM in reply to: wilkhui
Thank you for detailed instructions, but I option "convert to base feature" is not available when I right click on mesh feature. I have checked my Control Panel and Mesh Enabler is properly installed. I have checked Add-inn manager, Mesh Enabler is not there. I just don't understand what is happening. Could this mesh enabler be included in next Service Pack so we don't have to go through this hassle? Thx.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
