Inventor Forum
Converting 3D sketch to 2D sketch, from an igs file using wires
11 REPLIES 11
Message 1 of 12
4067 Views, 11 Replies
First we imported an ".igs" file to inventor, which produced "wires".  Then by promoting the wires it produced a 3-d sketch.
The model is in one plane and 2-D, and we are trying to use Ansys 2-D analysis, but in-order to do so it needs to be in a 2-D sketch.
The model is too large to be redrawn on a 2-D plane, does anyone know how to convert it to a 2-D sketch
11 REPLIES 11
Message 2 of 12
AustinLiu
We are sorry for the inconvenience.
But currently there is not a direct solution. The only workaround I can see here is to create a new 2D sketch and project the 3D curves to 2D.
I will pass on this requirements to our development team too.
Austin-Zongjie Liu
Zongjie.Liu@autodesk.com
Software Quality Assurance Manager
Design, Lifecycle & Simulation
Autodesk, Inc.
Message 3 of 12
ipburbank
in reply to: AustinLiu
How can I accomplish this?
Message 4 of 12
AustinLiu
in reply to: ipburbank
May you please share me a sample to let me have a try?
If you want, you can email me. Zongjie.Liu@autodesk.com
-Austin
Austin-Zongjie Liu
Autodesk, Inc.
Message 5 of 12
ipburbank
Here is a sample. Thanks for looking into it!
Istvan.
Message 6 of 12
AustinLiu
Please check the attached zip file to see whether it's expected
I also attached my workflows to show how I made it.
please let me know if any further questioins and thanks for your feedback.
-Austin
Austin-Zongjie Liu
Autodesk, Inc.
Message 7 of 12
ipburbank
Fantastic, thanks!
How did you do it?
Message 8 of 12
AustinLiu
I attached another zip file in my last reply; in the word document I described the workflow.
Please let me know if any further questions.
Again, thanks for your feedback.
-Austin
Austin-Zongjie Liu
Autodesk, Inc.
Message 9 of 12
klapec
Hi
another solution (Inventor 2013).
Message 10 of 12
AustinLiu
in reply to: klapec
That's a good one. Thanks for sharing. 🙂
-Austin
Austin-Zongjie Liu
Autodesk, Inc.
Message 11 of 12
MaheshwarMD
Hello Austin,
Thanks for sharing the procedure.
But the problem is , if we want to reuse it to create solid extrude or revolve, we are unable to do the same.
Please let me know, how we can fix this issue
Mahesh
Message 12 of 12
AustinLiu
in reply to: MaheshwarMD
Hi Mahesh,
May you pleae share me a sample file when you are facing the problem? You can simply contact me via Zongjie.Liu@autodesk.com, with models and more details about the issue. I can take a look and back to you then.
-Austin
Austin-Zongjie Liu
Autodesk, Inc.
