Inventor General
Contributor jsr
jsr
Message 1 of 5 (577 Views)
Accepted Solution
Convert to sheet metal doesn't make all bends
577 Views, 4 Replies
04-02-2012 11:07 PM
Godmorning.
Iam having trouble with a part that I wont to convert to sheetmetal and make a drawing with bend annotations.
Converting the part goes fine but the flat pattern is only a "semi-flat-pattern" 2 of the 4 bends doesn't unfold.
I have a 8mm plate and the internal radius is 2mm and the external radius is 10mm and the bend angel is 10 degrees sow everything should be fine.
But how to add the last to bends to make my flat pattern unfold correctly?
Kind Regards
Jens
Inventor Professional 2012
Vault Professional 2012
Active Contributor
Message 2 of 5 (554 Views)
Re: Convert to sheet metal doesn't make all bends
04-03-2012 05:26 AM in reply to: jsr
Check your first sketch. The distance between the two 10 degree bends is not exactly 8mm and that is why it won't flatten.
Donald L.
Inventor Product Design Suite Premium 2014
Windows 7 Professional - 64 bit
HP h8-1380t - i7-3820 @ 3.6 GHz
10 Gb
AMD Radeon HD7950 3Gb
*Expert Elite*
Message 3 of 5 (540 Views)
04-03-2012 09:34 AM in reply to: jsr
Maybe something like this (see attached).
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Contributor jsr
jsr
Message 4 of 5 (516 Views)
04-03-2012 10:36 PM in reply to: JDMather
Thanks for the help.
Looking at your part makes me think it is funny how different ways of working in inventor can be.
Do you allways make the complete 2d layout and then add material afterwards?
Normally I would go directly to 3d and then manipulating (adding/removing) material but seems like that in sheet metal the sketched up part works better for this purpose.
Kind Regards
Jens
*Expert Elite*
Message 5 of 5 (505 Views)
04-04-2012 04:57 AM in reply to: jsr
jsr wrote:
Do you allways ....
I try to always avoid work - do it the easy way.  Sometimes I am more succesful at avoiding work than other times.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
