Hello All
My problem today is that I made a Model of a Part of a ship using surfaces rather than solids because the engineer thought it would be easier to bring into ANSYS program for analysis but he is now having a problem with it and I am looking into converting my current model to solid. I can do it but the method I thought of using is quite long winded and we are working to a tight deadline.
what I thought :-
1.open up the surface part
2.use "Offset/Thicken"
3.any clashes between parts make a sketch and cut away.
the problem is the amount of plates I have and the time it takes to sort them out.
can anyone think of a better solution to this problem?
Cheers
Andy
I have had experience with ANSYS before and it does tend to prefer surface models to solid models. Have you tried thickening each surface into a new solid and combining them
Ive attached and example file
Hope This Helps
Cheers
Chris
Design Engineer
Sheffield UK
