I just was upgraded to Inventor 2014. I've got an assembly that I want to convert into a weldment. The "Convert to Weldment" icon doesn't appear where it used to be in 2013. I cannot find a way to make it pop up. Is it no longer possible to use this button to convert a an assembly into a weldment?
Solved by CCarreiras. Go to Solution.
Solved by Curtis_Waguespack. Go to Solution.
Hi gaila,
Does this assembly have a Positional Representation? If so, it can not be converted to a weldment.
If not, do you see this behavior with all assemblies in 2014, or just this one?
I hope this helps.
Curtis
Curtis,
Thank you for your response. No, it does not have a position representation.
Hi gaila,
If you look on the Environments tab > Convert panel do you see the Convert to Weldment button?
I hope this helps.
Curtis
Curtis,
This is embarassing. I must have missed it during my sweep of all the buttons. Thank you for your help!
