Inventor Forum
Convert assembly to a weldment
5 REPLIES 5
5509 Views, 5 Replies
I just was upgraded to Inventor 2014. I've got an assembly that I want to convert into a weldment. The "Convert to Weldment" icon doesn't appear where it used to be in 2013. I cannot find a way to make it pop up. Is it no longer possible to use this button to convert a an assembly into a weldment?
5 REPLIES 5
Curtis_Waguespack
Hi gaila,
Does this assembly have a Positional Representation? If so, it can not be converted to a weldment.
If not, do you see this behavior with all assemblies in 2014, or just this one?
I hope this helps.
Curtis
in reply to: Curtis_Waguespack
Curtis,
Thank you for your response. No, it does not have a position representation.
Curtis_Waguespack
Hi gaila,
If you look on the Environments tab > Convert panel do you see the  Convert to Weldment button?
I hope this helps.
Curtis
Hi!!!
The "convert Weldment" button is now in the tab "Eviroments".
You can also place the button into the Assembly enviroment.
See pics in attach
 Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you!
CCarreiras
Curtis,
This is embarassing. I must have missed it during my sweep of all the buttons. Thank you for your help!
