I knew this is not a new problem, and I do search some people's solution. Even I followed up their way as
, but still I cannot get correct solid model when I try to convert attached STEP model to IPT. I just can get surface model, but I do not solid one.
Could somebody help me to convert it to solid model (ipt)?
Your help will be much appreciated.
There are many surfaces missing.
As this is simple geomtry - it might be fastest to simply redraw it using the original only for reference.
Why would you need it as a solid body - isn't this an off-the-shelf purchased item?
Thanks lot for your suggestion.
Unfortunately, this 3D model is provided by vendor.
Looks like I have to use surface model.
