Inventor Pro 2013.
I would like to make the part named "Frame_base" an assembly on its own. Please see the attachment. I am new to Inventor and I thought I could demote it but the selection is grayed out. The main reason I want to do this is because I would like to create a 2D drawing of it with a parts list to give to the welder. This will be my first drawing and maybe I'm doing this wrong. It appears that I need to bring in the base view file, and I don't see a way to do that unless the frame is its own assembly.
I have learned a lot about Inventor in a month but I haven't figured out how to move parts in and out of assemblies. Are there any good videos on this?
Thanks!
Allen
Solved by cbenner. Go to Solution.
A frame generator assembly IS it's own assembly. In your drawing you would point the view to that file (frame_base), if that's all you want to show. You would need to know where it lives in order to point the view generator to it. In your main assembly you can right click on that and select iProperties. This will show you the file location. Also, you can (from the main assembly) right click on it and select open. If it is open while you are placing drawing views, it becomes a choice in the "File" drop down box of your view generator dialog box.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
