Hi all,
I was given this shinkwrap model from a vendor that i believe is saved in Inventor 2014. It would be much appriecated if someone could convert this to a .step to use on my 2013?
Kyle
Solved by JDMather. Go to Solution.
Here you go.
I am new to the community but I am having same issue as Dudeman had. I was wondering if somebody can convert some file I have in .IPT formate to .step or .iges files? Please see the attachments.
Hello everyone,
can somone please convert this ipt. file to a STEP. file
(inventor 2013 file)
much appreciated,
Thank you,
Ivo
I was wondering if someone could help me conver this .ipt file to a .step file. Unfortunately the file is too large for me to attach but I have posted a link to GrabCAD where you can find the .ipt file. It is for the Parker 9N600S Needle Valve.
https://grabcad.com/library/parker-9n600s-needle-valve-1
Thanks!
Here is the original Inventor file (2015 format - EOP rolled up for small file size).
And the zipped STEP file.
