Hi!
I have a sheet metal part were I due to our manufacturing process, nibbler, would need to be able to control the exact measure in the flat pattern of the side for a mitered corner. See attached file.
When we nest multiples of the part, the triangle forms a square and it is consequently the side of the square that I want to control due to the tools in the nibbler.
Is there a smarter way to do this, other the unfold/cut/fold?
As of today we change the length of the flange until we get an acceptable result.
Solved by benyang.he. Go to Solution.
