From iLogic i got a lot of information. And i want to configure or display this in a form.
But without having to make parameters for everything.
Example:
Display the stocknumber of an ipart/iassembly.
Configure the parameters from a part in the main assembly.
Hope my question is clear.
Thanks, Xiffix
(Inventor 2014 trail)
Thanks for your fast reply
The ipropperties i can add into a form is only from the active assembly. I want the stocknumber from a subassembly.
Hi!
It's possible to control the part parameter from the main assembly.
Example:
Skel:1 - Is the part name in the main assembly browser
Altura_Total_Input - Is the part parameter
Altura_Total - Is the assembly's parameter created to match the part's parameter.
Now you can change the part's parameters in a form within the main assembly.
Now you can have parameters from other parts in the main assembly and you can place them in forms.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
If i understand you guys correctly i cant skip the "linking the ipropperty(from a part) to parameter(in the assembly)" part before adding it to a form?
Is there a way to make parameters with iLogic?
MultiValue.SetList("DINJIS", "DIN", "JIS")
This is only possible if there already is a parameter called DINJIS in this case.
And can i display part parameters into a form without the extra parameter in the assembly?
Thank you guys!
Dim oCompDef As ComponentDefinition oCompDef = ThisDoc.Document.ComponentDefinition oCompDef.Parameters.UserParameters.AddByValue("myParameter",1,kInchLengthUnits)
No, the form can only display information contained in the active document.
