I am new to Inventor so I'm sure there is an easy fix.
I would like to insert a wideflange steel profile into my .ipt drawing.
I thought I would use Content Center for this. However on the left model tree pane I select the 'Model' drop down menu and select 'Favorites'. 'Content Center' is listed but there are no content center components shown?
Am I using this feature correctly?
I believe my content center is installed correctly because I can 'Place from Content Center' in a new .iam file within the same project.
Thank you for your help.
Thank you for the prompt reply John,
Is there a tutorial on how to add Favorites? I can create a new group but I do not see how to add anything to my favorites. I keep trying to just SEE what is in my content center but it appears to be missing.
Or better yet a tutorial on how to insert a steel profile from content center into an .ipt file?
Thank you again.
A picture is worth a thousand words. I attached a screen capture of what I see when I select Favorites and Content Center. As you can see the "tree" is blank. I would expect to see all my content center items listed here.
Hello John,
If I am NOT on the 'Favorites' tab my only other option is the 'Model' tab and yes, I see my full model tree when I am on the 'Model' tab.
Still not sure how to just view the content center files. I'm sure i'm missing something stupid here.
See attached screen shot.
Hello John,
I am trying to place a 2D steel profile in a part file not an assembly file. I was hoping to use the content center as a quick way of placing 2D steel shapes that I can extrude. This would save me the hassle of drawing them out manually.
Thanks again for all your assistance.
@Anonymous wrote:Content center is for placing fasteners and such in assemblies.
Content Center also has iFeatures.
