Inventor General
Valued Contributor
Jefkee
Message 1 of 2 (532 Views)
Content center adjustment part possible?
532 Views, 1 Replies
06-19-2013 01:31 AM
Ive made a little mistake while making a content center part.
Is there anyway to edit the Ipart that i published into the content center? there is a custom property in there that i would like to have deleted.
Inventor 2013
cbenner
Message 2 of 2 (519 Views)
Re: Content center adjustment part possible?
06-19-2013 04:49 AM in reply to: Jefkee
From Inventor, do an "Open from Content Center".  Open the published item in question and (if there is more than one) pick a size.  Make sure you open it "As Custom", so you can save it someplace to work on it.
Once the part is open, make whatever changes you need to.  Save the part.  Go back to Content Center editor, and find the part family.  Right click and select "Replace Family Template".  Find and select the part file you just modified.  It should replace the CC part family model with the part you've just modified.
AutoCAD 2013; AuoCAD Electrical 2013; IV 2013 Professional: Tube and Pipe, Frame Generator, Content Center; Vault Professional 2013: Client, ECO
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
