Close. There is actually an installer on the installation media that
installs the standard libraries (InventorStandardContent and Parker)
into a pre-installed DM Server. This is available on the main
installation page, but I don't recall the precise wording right now.
Something like "install content center libraries", or some such thing.
That way you don't need to use Library Manager to import those libraries
onto the DM side. You'd only need to do that for any libraries that you
may have published to yourself, if any.
When using Library Manager, it's important to use the proper one. Since
when you have Inventor and DM Server installed, you essentially have 2
library server environments, each with its own Library Manager, you have
to pick the right one. You do that by navigating to the proper Windows
Program Group -- either Inventor or Data Management Server.
Finally, if you do actually have to import libraries from one
environment to the other, you need to make sure that the files being
moved are not in use by the MSDE process. You do this via the Services
snap-in -- for example, if you wanted to do what you describe below, you
would stop the Inventor MSDE instance, which is the service called
MSSQL$INVENTORCONTENT.
Hope this helps,
Jeff
RobV wrote:
> Thanks Jeff for the answer. Presently ParkerStandardContent.mdf and
> InventorStandardContent.mdf exist in the data folder under C:\Program
> Files\Microsoft SQL Server\MSSQL$INVENTORCONTENT. (my localhost)
> Before I start, I just want to confirm what will happen.
> To change from local to server (still on my computer) I would use the
> Content Center Library Manager. I pick Import and then select C:\Program
> Files\Microsoft SQL
> Server\MSSQL$INVENTORCONTENT\Data\InventorStandardContent.mdf.
> What do I call the library?
> (So this process should move my content library to the server located at:
> C:\Program Files\Microsoft SQL Server\MSSQL$AUTODESKVAULT\Data ?)
> Rob
> "Jeff Pek (Autodesk)" wrote in message
> news:4821151@discussion.autodesk.com...
>>I you install both Inventor (including content) and the Autodesk DM
>>Server, you will get 2 MSDE instances. It's up to you whether you want
>>to serve content "locally" (in the INVENTORCONTENT instance) or together
>>with the Vault data (in the AUTODESKVAULT instance).
>>So, you can move the files if you want, using the Import function of the
>>Content Center Library Manager in the Autodesk Data Management program
>>group. If you do that, you want to make sure that the INVENTORCONTENT
>>instance isn't running.
>>Let me know if you need more details on this.
>>Jeff
>>RobV wrote:
>>>Hi Jeff,
>>>It turns out that the InventorStandard... & Parker Standard MDF and LDF
>>>files had suddenly disappeared!
>>>They used to exist in this folder:
>>>C:\Program Files\Microsoft SQL Server\MSSQL$AUTODESKVAULT\Data which I
>>>believe is the "server side" on my local computer.
>>>I phoned my reseller tech support and he let me know I was the 5th
> person
>>>today to experience this. He walked me through the procedure to remove
> the
>>>Content Library from Add/Remove Programs and then do a change to
> Inventor by
>>>installing the Content Libraries. Now everything works but of course
> the
>>>Content Library now sits on the client side of my computer in the
> folder:
>>>C:\Program Files\Microsoft SQL Server\MSSQL$INVENTORCONTENT\Data
>>>Is it possible to manually move these files back to the other folder
> then
>>>reconnect them in inventor, using my server name (my computer name) and
>>>continue on?
>>>Rob
>>>news:4820835@discussion.autodesk.com...
>>>>You should be able to access your shared library by entering your
>>>>machine name, but only if you're using IIS. If your server install is
>>>>instead using the Autodesk Web Server, this won't work.
>>>>If that is true, you need to pick one or the other. A config file
>>>>(Inventor.exe.config) has a setting that controls this.
>>>>Jeff
>>>>RobV wrote:
>>>>>My server and client are on the same machine. I tried to access my
>>>Shared
>>>>>Library (Remote) by putting my Server name (localhost) in the text box
>>>but
>>>>>no luck adding the content library. I have also tried putting in my
>>>machine
>>>>>name. It took a few tries yesterday too but it worked. It came up
>>>blank
>>>>>again today.
>>>>>Rob
