All options relating to the content centre seem to have disappeared. When i try and add a structural shape via manage tab / author - I get the following message Structural Shape Library cannot be found or Content Centre isnt logged in, please check it and try again. i have checked the active project and it includes the content centre location. Also in an Assembly I do not have the option of placing from content centre. Any ideas and how do i log into the content centre
Solved by NickHorton8970. Go to Solution.
Are you using Vault? Try logging out and back in to the Vault. Sometimes Vault times out and logs you out in the background without you knowing it.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thanks, i have got this sorted now. It was down to the fact that the location path had changed to point at the actual libraries instead of their location.
Can u explain how u solved this issue. i am also facing same issue.
Thank you,
karthikeyan M
+91-9894814348
Are you managing content center libraries through Vault or desktop content?
For security reasons please do not post things like your phone # here.
Mark Lancaster
& Autodesk Services MarketPlace Provider
desktop content center only. but in my system content center files were not installed.(i checked through control panel content center not found)
You will need to run the Inventor installation again and select to install the content center.
Mark Lancaster
