Inventor General
Distinguished Contributor
zma1013
Message 11 of 20 (1,512 Views)
Re: Content Center error "Unable to create component"
09-13-2010 01:32 PM in reply to: s.borisov
Do the parts in question happen to be linked to another family?  That was my problem.  After the 2011 install, I got the same error with some of my components and after searching and looking around and stuff, I eventually broke the links from the original family that the components were made from.  For whatever reason, all my CC parts work fine now.  You may just want to look into that as a solution, backing up your CC first of course in case you would want to return it to the normal state.
Just throwing that out there.
IV2012
Windows XP SP3 32-bit
Intel Core 2 Duo 6400 @ 2.13 GHz
Nvidia Quadro FX 3450/4000 SDI 256MB Vram
2 GB Ram
160GB HDD
Active Member
s.borisov
Message 12 of 20 (1,489 Views)
09-14-2010 08:19 AM in reply to: zma1013
I still have the problem. The Content Center practically is unusable for me:smileysad:
Distinguished Mentor
pauldoubet
Message 13 of 20 (1,473 Views)
09-14-2010 01:11 PM in reply to: s.borisov
I would recommend you try saving a CC part from a family you are having problems with using the 'As Custom' option and save the file to your Work Space. If you are successful doing this then I would suspect you do not have the correct permissions set for the directory you are attempting to save to with a 'Standard' CC part. I have seen the 'Unable to create Part' message previously if your Inventor directory for CC parts is located under the Program Files directory.
Hope this helps, Paul
Active Member
s.borisov
Message 14 of 20 (1,456 Views)
09-14-2010 09:50 PM in reply to: pauldoubet
The same result:smileysad: My CC directories are located in partition D:\Account name Documents\Inventor\Content Center Files\R2011
RobJV
Message 15 of 20 (1,444 Views)
09-15-2010 10:05 AM in reply to: cwhetten
I have had the exact same error message come up for me in the past.  I am on Vault though.  My barbaric solution was to find the part and delete it in my Vault and then I was able to reinsert it into my assembly.
Probably does not help you because it sounds like your user is not using vault.
Rob
Active Member
s.borisov
Message 16 of 20 (1,438 Views)
09-15-2010 10:26 AM in reply to: RobJV
You're right Rob- I'm using Desktop, not Vault.
Stoyan
Active Member
s.borisov
Message 17 of 20 (1,389 Views)
09-20-2010 09:10 AM in reply to: s.borisov
Two months after the first post in this topic and the problem is still there:smileysad:
*Pro
Dennis_Jeffrey
Message 18 of 20 (1,377 Views)
09-20-2010 09:54 AM in reply to: s.borisov
Wild Shot.....   do you have Excel installed (what version please)?
Can you create an iPart?
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Active Member
s.borisov
Message 19 of 20 (1,371 Views)
09-20-2010 10:56 AM in reply to: Dennis_Jeffrey
Yes, I have Excel installed. It's a part from Office 2007 SP1 fully updated and I can create iParts.
TOOCH
Message 20 of 20 (1,253 Views)
11-01-2010 07:55 AM in reply to: cwhetten
I had the same problem when I tried to place a content center part into an assembly, but I have located my prolem and that is empty fields in the Family table. I have created my own customized cc-parts and added an column with ordernumbers and not every dimension has one so I left them empty and that resulted in "unable to create component" for those who had empty fields.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
