I have Inventor installed on my computer, Its inventor 2012. I am trying to figure out why my content center is not working. In my App Options/ Content Center, The access option is set to Inventor Desktop Content then there is a file directory, Autodesk/Inventor 2012/ Content Center.... Now if i go to that location there is nothing in that folder. Should content center automatically be loaded when Inventor is installed or is it a downloadable add on. Thanks
Solved by blair. Go to Solution.
Did you select the Libraries when Inventor was installed? You may need to run the install program/repair again and select the CC libraries
Thanks Blair i assumed that something like that would be the solution. The program is normally installed by IT staff and it is something that was easily looked over by them no doubt. I will un-install and reinstall myself. Thank you
