Inventor General
Active Member
Message 1 of 6 (487 Views)
Accepted Solution
Content Center Non-Unique Filename(s)
487 Views, 5 Replies
07-19-2011 06:57 AM
I'm having problems creating / editing custom families in Content Center.
I have a read/write library setup and am trying to add families of fasteners to it. (Different grades and coatings)
I save copy as the fastener I want (ex Hex Cap Screw)
I can edit the family properties fine.
When I edit the family table and try to save, I get an error saying non-unique filename(s) found. I have not added any rows to the table. I am only trying to edit the parts description and part number to reflect our internal ordering system. I looked through the table and cannot find any duplicates.
Using Inventor 2011 SP2, Vault Client Build 15.0.58.0, Vault Server original build
*Expert Elite*
cbenner
Message 2 of 6 (477 Views)
Re: Content Center Non-Unique Filename(s)
07-19-2011 08:47 AM in reply to: bcamilly
More than likely your filename column is set up as an expression using one or more of the columns you edited... somehow creating a non unique filename.  To check this, right click on the heading of the Filename column and select Column Properties.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Active Member
Message 3 of 6 (475 Views)
07-19-2011 08:55 AM in reply to: bcamilly
Even with out editing any columns, and only adding one new column to use internally, it complains about the filenames. This new family being an exact copy of the STD family included with inventor.
Message 4 of 6 (449 Views)
07-21-2011 06:12 AM in reply to: bcamilly
Bring the family table into Excel and sort the data.  I have had this issue where the original filenames were already duplicated and when I saved as a new, this error would come up.  I found that there were just doubles of 1 of the parts.
- Aaron -
IV 2010 Tube & Pipe SP4; ACAD Mechanical 2010;
2.5 ghz Xeon Processor
8 gb RAM
Windows 7 Professional x64
EVGA GTX 560 2gb DDR5
*Expert Elite*
cbenner
Message 5 of 6 (442 Views)
07-21-2011 06:16 AM in reply to: doubleA26
Good call, now that I think about it I had this happen on a fitting once, there was a duplicate and the error didn't pop up until I had copied the item into out custom CC.
ChrisB
Active Member
Message 6 of 6 (441 Views)
07-21-2011 06:17 AM in reply to: doubleA26
I found the issue, It was duplicate file names. The 1" bolts were all labeled as UNC even though the table numbers showed fine threads. I deleted the offending rows and all is well.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
