Inventor Forum
Content Center Library
2 REPLIES 2
pompeo79
1235 Views, 2 Replies
Hi to all,
if i have created a custom content center library,  where all content center parts use my material "Steel XYZ", is there a way to use it in old assemblies that use a no custom content center library?
I mean, i have 100 assemblies that use bolt with Steel Mild material... can i change that material changing thecontent center library and using mine that use "Steel XYZ"?
Thanks for support!
2 REPLIES 2
cbenner
in reply to: pompeo79
You would need to open each of those assemblies and use Replace From Content Center on the parts.  You can do a "Replace All" on each part, but there is (unfortunately) no magic button that will just switch all of your fasteners to the new library.  If the fasteners came from a read only library, you may be stuck replacing them all the old fashioned way.
pompeo79
in reply to: cbenner
Thank You Chris!
