Inventor General
Valued Contributor
pompeo79
Message 1 of 3 (176 Views)
Content Center Library
176 Views, 2 Replies
12-11-2013 02:34 AM
Hi to all,
if i have created a custom content center library,  where all content center parts use my material "Steel XYZ", is there a way to use it in old assemblies that use a no custom content center library?
I mean, i have 100 assemblies that use bolt with Steel Mild material... can i change that material changing thecontent center library and using mine that use "Steel XYZ"?
Thanks for support!
cbenner
Message 2 of 3 (156 Views)
Re: Content Center Library
12-11-2013 05:40 AM in reply to: pompeo79
You would need to open each of those assemblies and use Replace From Content Center on the parts.  You can do a "Replace All" on each part, but there is (unfortunately) no magic button that will just switch all of your fasteners to the new library.  If the fasteners came from a read only library, you may be stuck replacing them all the old fashioned way.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Valued Contributor
pompeo79
Message 3 of 3 (152 Views)
12-11-2013 06:22 AM in reply to: cbenner
Thank You Chris!
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
