Inventor General
Message 1 of 5 (403 Views)
Accepted Solution
Content Center Issue
403 Views, 4 Replies
06-08-2012 01:08 AM
I get the following error when I try to insert screws into a new assembly:
Unable to successfully update the member part file. Problem occurred when setting thread data.
I click OK and the part inserts but the thread does not look right! Compare the threads on the screws on the left (shown incorrect) with those on the right!
Anyone have a cure for this issue or come across it before?
Using Inventor 2013.
Valued Mentor
japike
Message 2 of 5 (379 Views)
Re: Content Center Issue
06-08-2012 07:16 AM in reply to: Francis.Foley
We had that same issue. In our case, we deleted the sheet that Inventor needed, in the thread spreadsheet, to get it's thread data for content center. Once we restored that sheet, threads on content center parts worked fine.
Peace,
Jeff
Inventor 2013
Message 3 of 5 (376 Views)
06-08-2012 07:24 AM in reply to: japike
Jeff,
Where can I find the thread spreadsheet and where did you restore it too?
Francis
Valued Mentor
japike
Message 4 of 5 (370 Views)
06-08-2012 07:34 AM in reply to: Francis.Foley
The spreadsheet should be in your design data folder. It's called "Threads" I beleive. If you are on Inventor 2013, it will be in ".......\Design Data\XLS". We have a common copy that we keep on our server that we make modifications to as neccessary. When I needed to restore the sheet, I opened the spreadsheet from the Design Data folder that was created when Inventor was installed and copied the sheet from there to the spreadsheet on our server.
Peace,
Jeff
Inventor 2013
Message 5 of 5 (360 Views)
06-08-2012 08:19 AM in reply to: japike
Thanks for giving me a clue, I open the spreadsheet, resaved it and put a copy on my server content folder. I had to open the screws in the conents folder and fix them, there was only a few but I tried inserting some new screws without issue.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
