If you want to use the content library and make it available to different
users on a network, I believe that you will need to place your content
library in an accessible area on your network, and then set all clients to
use that as their content library. The file path can be set for each project
in the 'folder options', acessible in the project editor window.
Derek
"Quinn Zander" wrote in message
news:41e00c29_1@newsprd01...
> Goto the first "page" in Content Center and hit the Edit button at the
> bottom.
> You can set "where" you want the Content Center stuff to be placed. You'll
> have to set it on each workstation.
> QBZ
> "kellyhoyer" wrote in message
> news:29995066.1105200906541.JavaMail.jive@jiveforum2.autodesk.com...
>> We are just getting started with Inventor and one of our engineers has
>> started using parts from the content center files. ie bolts, nuts, and
>> washers. This is a great feature and we are very excited.
>> However, I tried to insert his assembly into an assembly that I am
>> working on and all of the content center files are unable to load. They
>> are pointing to somewhere on his personal hardrive I believe, in the
>> documents and settings folder.
>> Obviously we are doing something wrong. I don't really even know where
>> these library parts come from.
>> We are running on a network. If anyone has some insight on this I would
>> be deeply appreciative.
>> Kelly
