Inventor Forum
Content Center Causing Inventor To Crash
9 REPLIES 9
Message 1 of 10
1385 Views, 9 Replies
We recently received new computers for our Design department and we are having a few problems. When changing part sizes in content center (custom parts and standard parts) Inventor crashes every time. We can change part sizes with no problems with the older computers that we are using. This leads me to believe that Inventor doesn’t like something about the newer CPU.
Here are the System Specs:
System
Manufacturer
LENOVO
Processor
Intel Xeon CPU E3-1240 v3 @ 3.40GHz 3.40 GHz
Total amount of system memory
16.0 GB RAM
System type
Windows 7 Pro 64-bit operating system
Number of processor cores
4
Storage
Total size of hard disk(s)
1098 GB
Disk partition (C:)
SSD 60 GB Free (153 GB Total)
Disk partition (D:)
HDD 858 GB Free (932 GB Total)
Media drive (E:)
CD/DVD
Disk partition (F:)
HDD (Recovery) 799 MB Free (13 GB Total)
Graphics
Display adapter type
NVIDIA Quadro K2000
Total available graphics memory
9946 MB
      Dedicated graphics memory
2048 MB
      Dedicated system memory
0 MB
      Shared system memory
7898 MB
Display adapter driver version
9.18.13.1170
Secondary monitor resolution
1920x1080
Primary monitor resolution
1920x1080
DirectX version
DirectX 10
Network
Network Adapter
Intel(R) Ethernet Connection I217-LM
Does anyone have any idea what might be causing this? I would appreciate any help you might be able to give me. I’m running out of ideas to fix this.
9 REPLIES 9
Message 2 of 10
Cadmanto
Is your CC on your local or on a network?  Are you using Vault at all?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 10
in reply to: Cadmanto
We are using Vault Workgroup 2014 and Inventor 2014.
Message 4 of 10
Curtis_Waguespack
Hi jddickson,
Sometimes when a new machine is setup we forget about the updates. Do you have all the service packs & hotfixes for your version of Inventor installed?
I hope this helps.
Curtis
Message 5 of 10
Cadmanto
What about the location of your CC?  Network or local?
Are the settings on the new machine the exact same as the old ones?
Best Regards,
Scott McFadden
Message 6 of 10
We have all the service packs for the computers and Inventor is up to date. We are going to reboot the server with Vault on and see if it helps anything (also going to make sure that our Vault has the latest service pack).
Cc is located on our Vault and we only have one Project file for the whole company. Everything seems to be set up exactly the same as the old ones (going to try to do a little more digging to make sure).
I appreciate everyone’s quick responses.
We have a 3rd party software that works with inventor (it an iProperty manager) and the newer CPUs have an updated version of it on their systems.  That is the only differences I can find between them.  I’m going to try to uninstall it and try the older version…
Message 7 of 10
aparrow
Make sure the Vault Workgroup Client software is at the same level as your Vault Workgroup Server (ADMS) software. I had similar issues back with 2013 until I realized my server was not at the same level as my new clients.
I'm also running Vault Workgroup 2014 and both the client and server are at "Build 18.1.8.0 Update 1". I've attached screen shots for the heck of it.
Message 8 of 10
in reply to: aparrow
That's weird. I have 2 id's here.....
Message 9 of 10
cmharb
"We have a 3rd party software that works with inventor (it an iProperty manager) and the newer CPUs have an updated version of it on their systems.  That is the only differences I can find between them.  I'm going to try to uninstall it and try the older version"
Try removing this, i had a lot of trouble a while back with frame generator not inserting the frame members. We were using a 3rd party iProperties program that forced us to enter some of the iProperties before the new part/assembly was inserted. I cant remember the name of the iProperties program because it was removed a while back now, but it had a little round gauge  to show how much of the iProperties had been entered.
Once removed everything worked fine.
It was a shame because it was a handy little plugin.
w7u-64sp1,iv14,intel.xeon.e5-2620 0 @2.00 2.00-32gb,gtx560-4gb
Message 10 of 10
Cadmanto
I had two ID's as well for the vault.  One for the everyday user and one for the administrator side of things.
We had our CC located on the network and the only CC files that were in the vault were the ones inserted into assemblies once checked in.
Not the entire CC.  I am guessing this is the same case for you.  If you go to application options under the "File" tab it will show you where your CC is located.
As far as the third party software, I would try and disable it instead of uninstalling it for starters.  Or upgrade just one of the older machines and see if it gives you the same results.  What is the purpose of this third party software anyway?  I ask because I am wondering if what ever it is doing can be accomplished in other ways like iLogic or whatever.
Best Regards,
Scott McFadden
