I have some "insert" constraints for DIN rails in holes. I've moved the holes, but the DIN rail doesn't move. The refresh button isn't "lighting up", or when it does, it does not do anything to move the rail. Is there something that's been "shut off" to keep things from moving?
Can you attach assembly that exhibits this behavior?
tools..application options..assembly tab. Is defer updates checked?
Any of the parts "grounded"? (this would throw and error though I believe)
I checked but there are no grounding issues. Also, the delay constraints is not checked, so I'm not sure why there is a problem.
Here is the assembly.
Of course an assembly without parts is useless.
I have not attached assemblies before, I didn't realize it wouldn't include the parts. That's all.
Here is an example of a part in the assembly I'm having issue with (DIN Rails and Wireways).
