Inventor Forum
Constraints for assembly.
2 REPLIES 2
methoni
214 Views, 2 Replies
Having drawn the plate with holes , added the webs etc i now wish to put a load onto the plate surface to see the deflection,putting on the load has been easy, but when i try a simulation an error message keeps coming up " no constraints".
As far asi am aware i have constrained the webs to the plate.,the plate is not grounded,the only parts that are grounded are the 4 round feet.
What i am trying to do is create a scenario where the plate is acting like a table (the round feet acting as the legs) a load is then put on the top surface of the table-i wish to see the maximum deflection/distortion to ascertain the thickness of the required plate to avoid distortion.
Incidentally this assy is contained within the base of a pressure vessel.
The constraints problem does seem to be the sticking point.
Any suggestions please.
2 REPLIES 2
JDMather
in reply to: methoni
I recommend that you go through the tutorials first (an assembly must have parts).
An assembly file (*.iam) is only a list of hyperlinks to the part files (*.ipt) and a record of assembly constraints (and a bit more).
You must include the part files.
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
http://wikihelp.autodesk.com/enu?adskContextId=HELP_TUTORIALS&language=ENU&release=2014&product=Inve...
methoni
in reply to: JDMather
Thanks JD
I have solved the problem with additional constraints, originally the error was" not enough constraints".
The model is now reacting with the deflections in the expected areas.
Regards
