Inventor Forum
Constraint in sub assembly driven from main assembly
5 REPLIES 5
kajobus
1561 Views, 5 Replies
Hi, I have 4 different sub assemblies , each with a common part , I need to line up all these common parts in my main assembly, please can you point me to a tutorial or help file that shows how to do it . Regards
5 REPLIES 5
kajobus
in reply to: kajobus
Hi, I leave my common part under constrained with the part able to "move" in the sub assembly. After placing my sub assembly into my main assembly, I'm trying to use the "Flexible" option to "move" the under constrained part and contrain it to a work plane in the main assembly , but the "Flexible" option is not avalible (greyed out) , any ideas ? Regards
JDMather
Can you attach the assembly here?
Can you reproduce the same behavior in a simple trial example?
Can you at least post a screen capture?
kajobus
in reply to: JDMather
Please find attached greyed out image and pack & go , Regerds
JDMather
In your screen capture you left out the critical information.
In your word description you left out the critical information.
The sub-assembly is a weldment.
You would need to add the "flexible" part to the top level in the assembly or in a non-weldment subassembly.
Once you have them lined up you could then right click Component>Demote back into the weldment subs.
kajobus
Thank you
Regards
