Inventor General
Active Member
rjones0215
Message 1 of 8 (208 Views)
Accepted Solution
Constraint Virus?
208 Views, 7 Replies
05-02-2012 05:35 AM
For 3 or 4 days now, 90% of the time I place a mate or flush constraint, it automatically offsets to some random direction and I have to reset to zero.  Anyone know what might be causing this?
Inventor 2013 Certified Professional
*Expert Elite*
Message 2 of 8 (197 Views)
Re: Constraint Virus?
05-02-2012 05:59 AM in reply to: rjones0215
I have never seen this behavior.
Is this with 2013?
Do you have Predict Offset enabled?
Can you attach an assembly here that exhibited this behavior (accept the offset constraint - don't reset it to zero).  Only need the parts that are constrained.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Valued Mentor
Message 3 of 8 (195 Views)
05-02-2012 06:00 AM in reply to: rjones0215
In the constraint dialogue box you have ticked the box with an image of a ruler next to it. When ticked if faces are parallel the dimension they are offset by is automatically placed in the offset box.
Regards
Martin
PDSU 2014 SP1.3
Windows 7 64bit SP1, Office 2007 Pro
Intel i7 980x, 24 Gb DDR3 RAM
Geforce 580GTX Graphics (Diver 327.23)
256GB SSD OS, 80GB SSD working folder
Space Pilot
Employee
Message 4 of 8 (185 Views)
05-02-2012 06:08 AM in reply to: rjones0215
Hi! Could you show me an example by providing Inventor files or a video? What release of Inventor are you on?
Thanks!
Principal SQA Engineer, Inventor
Mechanical Design
Autodesk, Inc.
Active Member
rjones0215
Message 5 of 8 (183 Views)
05-02-2012 06:10 AM in reply to: rjones0215
Ha.  Yes, I must have clicked the "Predict Offsets" box.  I didn't even know if was there.  It's unchecked now and everything seems to be back to normal.  Thanks again.
*Expert Elite*
Message 6 of 8 (171 Views)
05-02-2012 06:55 AM in reply to: rjones0215
Then it should have been 100%  in your original problem description.
Watch out for this one as if your parts are already close to alignment you might not even notice the offset and this is one of the few setting changes that persist after leaving the dialog (I think even after leaving a session of Inventor - but I would have to check on that).
Active Member
rjones0215
Message 7 of 8 (169 Views)
05-02-2012 06:58 AM in reply to: JDMather
I believe you are correct.  In the future, I will be more cautious of this.
Valued Mentor
Message 8 of 8 (151 Views)
05-02-2012 07:36 AM in reply to: rjones0215
It does persist across sessions (I normally have it turned on). It does only work when the mating faces are aligned though, if there is any rotation then the value remains zero.
Regards
Martin
PDSU 2014 SP1.3
Space Pilot
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
