> Is there anyway to constrin a work point to
> a curved line, or a work point to a curved surface.
I guess the anwer must be; "No".
> I need to constrain a cylinder inside a
> 180 degree & 890 degree bends in a pipe,
> and be able to make it travel thru the bend.
See attached. It, or something of the sort, might get you
where you want to go. It does require some setup. Actually
it's a bit of a pita and some of the requirements may not be
evident to the casual observer, so holler if you want more
info.
Load Assembly1, look for assy workplane "MOTIVE" and its
"DRIVER" constraint. (This works in IV7, suppose it should
still work in 8 & 9.
