Hi
Is there a way or method to use center lines or points as constraints? I very recently had to constrain a cylinder to a 3mm flt bar (at the end with the bar positioned perpendicular to the cylinder)
I couldnt find a successful way of constrainting these together. i couldnt mate them because i couldnt select the cylinder face. In this instance, how could i do that?
Nigel
Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
Attach your assembly here.
I'm sure there is an easy solution.
Hi
assembly & files attached
Nacho
A part was missing from your attachment - so I couldn't figure out your problem - but maybe attached assembly will help.
