Running IV 2013 (jut upgraded from 12). When I constrain two components, the face, or bore or line which I am constraining no longer highlights BEFORE I click. Anyone else notice this? Is there a setting?
Nick
Solved by Accudyne1. Go to Solution.
If you look in your application options under colors and the 'Enable Prehighlight' option is not selected that might cause this issue.
