Inventor General
whunter
Message 1 of 7 (343 Views)
Constraint Glyphs
343 Views, 6 Replies
05-09-2012 07:56 AM
Hi all,
anyone know of a way to show glyphs in order to display different types of Constraints in the Stress Analysis Environment? It is very annoying to double-click (edit) the Constraint just to see what the constraint is. Hovering with the mouse over the Constraint in the browser also doesn't reveal anything.
With Loads you can at least see the force vector glyph.
*Expert Elite*
cbenner
Message 2 of 7 (331 Views)
Re: Constraint Glyphs
05-09-2012 09:58 AM in reply to: whunter
Doesn't the standard F8 work in that environment?  I never use it so I don't know.  In base Inventor F8 will show all constraints... F9 shuts them back off again.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
whunter
Message 3 of 7 (314 Views)
Re: Constraint Glyphs (Stress Analysis)
05-10-2012 03:26 AM in reply to: cbenner
No, that doesn't work. I also don't know if it has changed in 2013 (haven't had a chance to install yet), it wasn't there in the beta.
I'm not sure there is a way, it would have to be a plug-in or add-on, perhaps someone knows of such a plug-in?
The FEA in Inventor has a lot of potential (it's already quite good), just a few small things on the UI that needs to be sorted out...
*Expert Elite*
JDMather
Message 4 of 7 (306 Views)
05-10-2012 03:50 AM in reply to: whunter
Clicking on the constraint in the browser should highlight the face that it is applied to  (don't need to edit).
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
whunter
Message 5 of 7 (299 Views)
05-10-2012 04:35 AM in reply to: JDMather
JD, yes it does, but then I still don't know exactly what the constrains are, eg, for a pinnned constrained: is radial fixed, or axial, or tangential, or any other combination of those three?
One picks the constraints in a dialogue box, so it would be enough if the constraints were added to the browser names, eg:
Pin Constraint: Bush (DR DA)
Then I know that it is fixed Radially and Axially. I do that manually, but it's cumbersome and error prone.
*Expert Elite*
JDMather
Message 6 of 7 (288 Views)
05-10-2012 08:33 AM in reply to: whunter
Algor, SWx, and Creo do a better job of this.
Might be worth a future request.
whunter
Message 7 of 7 (282 Views)
05-10-2012 08:47 AM in reply to: JDMather
I have already.
Just thought someone on this forum had a plug-in or add-in that could do constraint glyphs already, since I don't know when it's going to get implimented, or if it ever will.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
