Hi all,
anyone know of a way to show glyphs in order to display different types of Constraints in the Stress Analysis Environment? It is very annoying to double-click (edit) the Constraint just to see what the constraint is. Hovering with the mouse over the Constraint in the browser also doesn't reveal anything.
With Loads you can at least see the force vector glyph.
Doesn't the standard F8 work in that environment? I never use it so I don't know. In base Inventor F8 will show all constraints... F9 shuts them back off again.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
No, that doesn't work. I also don't know if it has changed in 2013 (haven't had a chance to install yet), it wasn't there in the beta.
I'm not sure there is a way, it would have to be a plug-in or add-on, perhaps someone knows of such a plug-in?
The FEA in Inventor has a lot of potential (it's already quite good), just a few small things on the UI that needs to be sorted out...
@whunter wrote:Hovering with the mouse over the Constraint in the browser also doesn't reveal anything.
Clicking on the constraint in the browser should highlight the face that it is applied to (don't need to edit).
JD, yes it does, but then I still don't know exactly what the constrains are, eg, for a pinnned constrained: is radial fixed, or axial, or tangential, or any other combination of those three?
One picks the constraints in a dialogue box, so it would be enough if the constraints were added to the browser names, eg:
Pin Constraint: Bush (DR DA)
Then I know that it is fixed Radially and Axially. I do that manually, but it's cumbersome and error prone.
Algor, SWx, and Creo do a better job of this.
Might be worth a future request.
@Anonymous wrote:Algor, SWx, and Creo do a better job of this.
I have already.
Just thought someone on this forum had a plug-in or add-in that could do constraint glyphs already, since I don't know when it's going to get implimented, or if it ever will.
