Inventor Forum
Constraining Sketch entities to a plane
5 REPLIES 5
Cadmanto
2109 Views, 5 Replies
How does one constrain a sketched lin in the sketcher to a datum plane?
Best Regards,
Scott McFadden
(Colossians 3:23-25)
5 REPLIES 5
cbenner
in reply to: Cadmanto
Cadmanto
in reply to: cbenner
Being new to Inventor, what do you mean by "Project Geometry"  are you talking about construction lines?
My thinking is that I should be able to select my construction line or center line then select the plane and hit coincident
and the two snap together, but that is not what happens.
Best Regards,
Scott McFadden
JDMather
While in sketch mode there is a Project Geometry icon (have you used other parametric software like SWx or Pro/E so that I can use similar terms to those).
Inventor is not aware of any geometry that hasn't been created by you in the sketch or projected into the sketch.
You might read this document http://home.pct.edu/~jmather/skillsusa%20university.pdf
cbenner
Cadmanto
in reply to: JDMather
Yes, I am very familiar with Solidworks.
I am generally struggling with how the contraints work in Inventor.
I get them to work sometimes and not at other times.
In Solidworks I am used to creating construction or centerlines
then selecting the ones you want constrained and selecting the constraint
and the two snap together.
Best Regards,
Scott McFadden
