style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Larry Caldwell" <
href="mailto:lc@houston.rr.com">lc@houston.rr.com> schreef in bericht
href="news:76C73D738BE747321229C5077680E5CB@in.WebX.maYIadrTaRb">news:76C73D738BE747321229C507768......
Was just making another O-Ring and remembered
I never got around to posting on this topic. From the answers
I've read on constraining O-Rings and such, I noticed I haven't seen my
technique mentioned (not to say it wasn't, but I didn't see it). What I do is
extrude a surface on the ID in both directions that equals the o_ring
diameter. Then I usually place an iMate so I don't have to turn the surface
back on to constrain it with a single insert constraint.
~Larry
"Cor J. de Vlaming" <
href="mailto:c.devlaming@bakker-hydraulic.com">c.devlaming@bakker-hydraulic.com>
wrote in message
href="news:3F8A2DFBBEC9738F16B8A3A7C0B43E08@in.WebX.maYIadrTaRb">news:3F8A2DFBBEC9738F16B8A3A7C0B......
The best way to constrain a o-ring is to
construct the o-ring on the origin center (project geometry- origin
centerpoint)
then you can use all plane and axis to constrain
for example you can now use the z-axes to mate-constrain with the tube and the
x or y plane with a plain of the tube + 1/2 cord-diameter
greetings Cor
"Larry Caldwell" <
href="news:76C73D738BE747321229C5077680E5CB@in.WebX.maYIadrTaRb">news:76C73D738BE747321229C5077......
is extrude a surface on the ID in both directions that equals the o_ring
size=2>~Larry
"Larry Caldwell" <
href="mailto:lc@houston.rr.com">lc@houston.rr.com> wrote in message
href="news:DB9FCA8CBEFABDBD280A17DCF0EAC2BF@in.WebX.maYIadrTaRb">news:DB9FCA8CBEFABDBD280A17DCF0E......
Yeah ... but, then again, you have to turn
'em (the planes/axis') on/off in the assy to constrain 'em. With the surface
(project the ID/Extrude to length) you can place any kind of iMate you want
and plop it in without even going to the browser. Not saying any way is better
than the other, just saying how I do it. Never know who might get some
use out of it.
~Larry
wrote in message
href="news:3F8A2DFBBEC9738F16B8A3A7C0B43E08@in.WebX.maYIadrTaRb">news:3F8A2DFBBEC9738F16B8A3A7C......
centerpoint)
constrain for example you can now use the z-axes to mate-constrain with the
tube and the x or y plane with a plain of the tube + 1/2
cord-diameter
greetings Cor
"Larry Caldwell" <
bericht
href="news:76C73D738BE747321229C5077680E5CB@in.WebX.maYIadrTaRb">news:76C73D738BE747321229C50......
remembered I never got around to posting on this topic.
From the answers I've read on constraining O-Rings and such, I noticed I
haven't seen my technique mentioned (not to say it wasn't, but I didn't
see it). What I do is extrude a surface on the ID in both directions that
equals the o_ring diameter. Then I usually place an iMate so I don't have
to turn the surface back on to constrain it with a single insert
constraint.
size=2>~Larry
