Inventor General
Active Member
aheiselberg
Message 1 of 3 (385 Views)
Constrain point to curved line
385 Views, 2 Replies
11-23-2012 06:24 AM
Hi folks
I have an assembly with a curved line made in a sketch, and a part with a point in the bottom.
I want to constrain the point to the curved line, but the regular Constrain options wont let me do so.
Is there any work-around or a tip for this?
The attached pic might make it easier for you to see what I want.
I am making an animation with Inventor Studio, so I need this constrain, so I later on in studio can manipulate it and insert the first part into the other.
blair
Message 2 of 3 (353 Views)
Re: Constrain point to curved line
11-23-2012 02:58 PM in reply to: aheiselberg
Can you place a Work Point on the line at the point required. If so, then use the Work-Point to constain to. Or extrude the line as a surface and costrain to it. If you use the constraint distance to match the radius it will match.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Active Member
aheiselberg
Message 3 of 3 (299 Views)
11-28-2012 02:04 AM in reply to: blair
I couldn't figure out how to extrude the line as a surface, but I did a workaround and created the curved line as a part instead. The surface of this part was able to create the constrain, as you described. Worked perfectly!
Now I just have to make the part invisible, and I am good to go.
Thank you for you help.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
