Inventor General
Valued Contributor
Message 1 of 2 (173 Views)
Constrain multiple parts at the same time?
173 Views, 1 Replies
07-15-2013 10:00 AM
I've got a situation that I'd like to constrain about 100 parts at the same time to the same plane. They are the same part, copied over and over.
Is there any way to do this quickly?
Unfortunately, a component pattern is not an option in this situation as the spacing is very irregular.
I'm in Professional 2014, btw.
Employee
Message 2 of 2 (134 Views)
Re: Constrain multiple parts at the same time?
07-16-2013 12:21 AM in reply to: schnautza
You can try to use iMates. Define iMate on each part and in the Place Component dialog enable Interactively place with iMates option. This will generate constraint (iMate results) of the same iMate type. Note that once an iMate is consumed it can not be used again - so it will not help for your issue :-( However if the plane contains holes you can create insert iMates for the holes and then during the second part insert it will constraint the part to the selected hole.
Csaba
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
